kipkippo
Registered Member
when I was pulling my intake manifold off today I spilled some coolant into the engine I was wanting to change the oil any ways but I was wondering before I put it back together if as long as I can clean what I see and change the oil and coolant will I be ok
... this blazer I becoming a nightmare
I need to know the size for the bolt on the bottom front pulley so I can turn the engine over to TDC so I can install my distributor correctly
But I have a question. I got the intake on. Is it ok if I just put 4 bolts in until tomorrow? so I can get it torque correctly or am I going to have to torque it with wet RTV? because it's another early morning off to work, and I don't have time to put all the bolts in and torque it tonight. Right now I have 4 bolts in 2 on each end just tight w/ a socket I am going to put the rest in tomorrow and finish it up after I get off work with some daylight
