Thought I should post this info since its valuable for others who are running into this issue. I recently replaced my cluster and my temp gauge was barely registering on the 1st tick mark. After doing some research I found the years can make a difference. I have a 1979 and I'm willing to bet my cluster was from 78 or older. This means the temp sensor and the gauge won't work together. The correct sensor for the older years should be AC Delco G1852. Thanks to @Wes Harden for that info. For the newer trucks, it will be a different sensor with higher ohm readings.
74-78 sensor:
For Truck Years: 1974 - 1978
The Temp Gauge Needle Should Point to:
Left Line (Cold) when sender resistance = 350 Ω
Middle Line when sender resistance = 68 Ω
Right Line (Hot) when sender resistance = 46 Ω
For Truck Years: 1979 - 1991
Left Line (Cold) when sender resistance = 1,365 Ω
Middle Line when sender resistance = 96 Ω
Right Line (Hot) when sender resistance = 55 Ω
I would first check the sender's resistance under actual operating conditions. Remove the sensing lead from the sender and - with the engine cold - get an initial resistance reading. One probe on the sender's terminal and the other to a clean nearby spot on the cylinder head. I used a muli-meter on ohms to verify what it reads when cold and warm.
As the coolant warms up, keep checking to confirm that the resistance across the sender begins to fall. Since you are getting absolutely no reaction out of the indicator, don't be overly concerned with the actual ohmic values. Just confirm that resistance does decrease as a function of coolant temperature rise.
If you are interested, here is the temp/resistance matrix for 79-91 GM coolant senders:
If the resistance tracks downward with an increase in coolant temperature (even if it's a bit off), I would say you could eliminate the sender end of the circuit as the problem.
As you can see from the chart, the indicator would like to see a resistance of about 1600 ohms to bump the needle off "C" (100 F). And, when the engine reaches normal operating temperature (coolant @ 195 F) resistance across the sender should be about 240 ohms - which should drive the needle to just left of the midway mark. This is for 79 and newer models.
Notice the white ceramic part behind the gauge. Thats the resistor. You can replace it with a standard 90-100 ohm resistor if you find yours to go out and the gauge is pegged even with a good sensor.
Also- If you ever want to test/check the gauge out of the vehicle, here is how to hook it up.
74-78 sensor:
