Coolant temp sensor intake adapter?
newoldscottsdale77
Sykesville MD
I cannot find an adapter to install a coolant temperature sensor in my edelbrock performer intake. I read here that i needed a 1/2" male pipe thread to a 3/8" female fitting. I bought the fitting but my sensor wont screw past 4 threads, they seem to be off just a little. What am i missing? The sensor has no abnormalities like burres or damaged threads. Fitting was from homedepot.
pipe thread is tapered...so the farther in you screw it the tighter the interference fit becomes.
that is correct,pipe threads are tapered,and get tighter as you screw em in,put a few wraps of teflon on it and you are good to go
