Hey all. Got a 87 Jimmy Sierra Classic with the 350 we bought in the spring. Havent driven it a lot due to a problem with the cooling if any one could give a few ideas would be appreciated. To start the thermostat had been replaced along with the fan clutch( or so I've been told). At an idle she never over heats but you go 5 miles down the road and she will start to get hot pretty darn quick. Last time she got out hot the upper and lower hose were reading about 190ish on my radar with the radiator underneath the pressure cap was around 220. Neither of the hoses are getting sucked in and there are no leaks so I think the cap is doing it's job. There is no antifreeze on the dipstick and it doesn't smell like antifreeze either. We also used a combustion leak test and found no problems. The water pump seems to be working because with the pressure cap off you can see water getting sucked down into the radiator when you step on the throttle. The fluid is disgusting looks like pong scum. We are going to change that. The only thing we have noticed is the large amount of air the fan is pushing out the front. Under the hood there is minimal airflow getting pushed into the engine bay. With my 94 k1500 you can feel and see the air move very well a small rag. Is it possible someone put a pusher fan on? The fan rotate counter close wise if you looking at it from the driver side fender. Any help or advice would be greatly appreciated. Thanks
