Hey guys, we got a cooling system problem over here that has us stumped. Hoping someone can help us out.
1987 K5, 350 TBI.
Having constant leak issues due to pressure, but it's not the head gasket. We've changed out & fixed just about everything, and it just keeps leaking(due to pressure).
What we've done so far:
-new radiator (nice copper 4 core)
-all new cooling hoses
-new thermostat
-new rad cap(x2)
-heater core bypassed atm(due to being blown)
Temps never gets high, it just keeps springing leaks. We fix one, it leaks somewhere else. Over and over. It's blown the heater core, a hole in the new radiator, and at damn near every hose. Just keeps finding the weakest leak and blows. Had the head gasket test and it passed fine(plus no head gasket symptoms), so it's not that.
Coolant circulation is fine so it's not the water pump.
Any ideas what could keep causing the pressure build up in the cooling system?
Possibly vacuum/vacuum hose related?
I don't think so, but maybe there's some blockage (maybe in the block somewhere) and should have the entire system flushed again (did this back when first installing radiator).
In short, what could keep causing excessive pressure other than head gasket?
We're running out of ideas, any help would be GREATLY appreciated.
1987 K5, 350 TBI.
-new thermostat
-new rad cap(x2)
