thealien
I am putting a 2005 5.3 into my 1972 Jimmy. I want to plumb the steam port into the radiator correctly. I know some block them off and some put them into the water pump or thermostat housing. I would like to have it installed correctly into my stock radiator with the top hose on the drivers side tank and the lower hose goes to the passenger side. I have heard/read that it matters what side of the radiator this gets plummed to (pressure side/low pressure side?)? Should this be above the attachment point of the top radiator hose or could it just be below it? I really would like to do this right
I will eventually install a purge/overflow tank but I just can not right now.
Mark
Mark
