Copper contact cleaner - Lemon Juice
badmix
West Virginia
Watching Power Block, they dumped some parts in a Lemon juice solution and sure as sh!t cleaned them up nice. Just thought id share. :D
You can boil carbs in lemon juice or vinegar (or a combo of both) to clean out all the crap left behind by ethanol ,which most petroleum based carb cleaners wont touch too...I've saved a few really raunchy looking small engine carbs with the lemon/ vinegar boiling trick..
I also put vinegar in a very rusted master cylinder that sat empty a long time and let it sit a few days--when I used a shop vac to suck it out,the insides were nice and clean,gray like sandblasted metal...
I did however,end up replacing the master due to the seals being ruined when I had tried forcing it to move, before the vinegar treatment...the vinegar may have softened the seals a bit,which isn't really a bad thing,because they had become hard and brittle from sitting..
Yeup. The point is the acid to eat off the top layer of copper.
When we owned the plating shop we used some citric acid for a lot of delicate parts. It's strong enough to clean but not so strong to eat the part to nothing.
