Core support and fender trimming
mckustomfab
Carrollton, Tx
Anyone out there done a trim job on the core support? I know there is tons of info on trimming the fenders and I have already cut mine up quite a bit, now I need even more room. I am trying to keep this truck as low as possible and the new front axle i am swapping in has more steering travel than my old D60.
I am looking to cut my fenders, grill and core support below the head light and remove the turn signal. I am planning to add some supports back to the core support, the idea is to keep the inner fenders to keep the crap out of the engine compartment. I found a Dodge that 4Wheel and Offroad built for their Ultimate Adventure a few years back, it is very close to what I am looking to do but I cant find any good photos of the core support. Anyone done anything like this?!?
Here is their Dodge
full
This is what I am working on, you can see a line above the turn signal, that is where I would like to cut.
full
The radiator support trimming is pretty straightforward and you should still have a couple bolts to keep the fender attached to it. Do you want the inner fender modified so it attaches to the radiator support?
Yeah, I plan to cut the inner fender and weld in some material to make it attach to the new raised core support section directly below the head light.
Anyone out there done a trim job on the core support? I know there is tons of info on trimming the fenders and I have already cut mine up quite a bit, now I need even more room. I am truing to keep this truck as low as possible and the new front axle i am swapping in has more steering travel than my old D60.
I am looking to cut my fenders, grill and core support below the head light and removing the turn signal. I am planning to add some supports back to the core support and the idea is to keep the inner fenders to keep the crap out of the engine compartment. I found a Dodge that 4Wheel and Offroad built for their Ultimate Adventure a few years back, it is very close to what I am looking to do but I cant find any good photos of the core support. Anyone done anything like this?!?
Here is their Dodge
full
full
I have not seen any details on this but that's exactly my goal and I am guessing you will be my Guinea pig :pimp:
While setting up my 4 link I decided to go ahead and trim the driver fender, of course I forgot to take any photos of the actual trim but in this photo you can see how high I trimmed the fender. I will get some better photos when I clean it up and start trimming the core support.
full
Here is a few pics of how the core support trimming is going, I have been working on it in between finishing up the suspension. so it has been a little slow. I still need to workout the inner fenders and trim the battery trays but I really like how it is looking!
Here is the side shot and you can see how high I trimmed the "fang"
full
I welded in some caps into the fender, it helped stiffen it up and will keep mud from getting up inside the fender. You can also see the brace I added to help re-enforce the core support after I trimmed for the innercooler and fender.
full
Front minus the headlight trim
full
*unlike
front hubs
:D
I need to take the plunge and do some cutting up front also, not at much, but still not looking forward to it. Might loose a lot of inner fender.
Here is a little update on the front end, got my LED signals hooked up and in the last two photos you can see that I trimmed the bumper more. Haven't decided what exactly I will do with the bumper but for now I plan to mount some LED floods under my turn signals and see how they fill it in.
Headlights, turn signals, and marker lights
full
full
You can see the new bumper trimming!
full
full
