corp 10 bolt u joints.
tumbleweed1002
copperas cove ,TEXAS
Hey all, can anyone tell me if I can change the u-joints on a corp 10 bolt front axle without pulling the ball joints? its under a 86 suburban.
Yep. Pull the lockouts, the hub/rotor assembly, don't forget caliper, 6 spindle nuts, and a BFH to knock the spindle off. Pull the shaft, change joint, reassemble.
