Randy Horn Hunter
Newbie
I've read multiple posts, new and old, discussing the correct "self-adjusting" switch for 1986 and other years.
I've now bought and returned three sets of switches that were supposed to be the correct switch, but the sleeve does not push through the nut to match the door gap when you try to close the door.
I have bought Chinese from LMC, and what was labeled as GM parts that were pictured as brass like to OEM but what I got was Delco that looked just like the LMC Chinese part.
There is a good description of the problem with photos on the squarebody forum but does not help find the right switch that works.
Anyone got a lead on right part?
www.gmsquarebody.com
Anyone know how to get to this switch?
Thought maybe there would be access once the kick panel was removed.. Not so! It's solid sheet metal there.. Looked in the jamb.. Crawled underneath the truck to see if there was any access from underneath... Nope.. Is there some trick I'm missing, or are we expected to fish it through...
