Hi Guys,
I am in the final stages of installing my axle from a previous post
http://coloradok5.com/forums/showthread.php?t=260593
Its a 14 bolt SF axle with an eaton electric locker and 5.13 gears. I purchased ORD shackle flip kit so I have removed the blocks. I need to set the pinion angle before I weld the spring perches on. What is the correct angle I should be shooting for. I am just using the stock driveshaft. I've read 2 degress is what I should go for. Is this correct? should I load the rear of the truck up before I set the angle?
Thanks for any help!
