FlatBlackBurb
the other day i got pretty drunk and decided to work on my truck. suprisingly i actually got a lot done. i got the fuel tank in and the new battery cables. but i guess i wired up the starter wrong because today when i connected the battery to try and start my truck (sober) sparks flew everywhere and the truck tried to turn over. i took a look down at the starter and found that the small black cable on the positive terminal was connected to the small post closest to the flywheel. not where it should have been. if i remember right its supposed to go to the alternator. so i wired up everything correctly and when i turn the key to start. nothing happens, my truck just "chimes" at me. i cant even hear a single sound from under the hood so im guessing i fried my starter. all fuses are ok.
so just to double check whats the correct wiring for a starter on a 1987 suburban. the starter has the main post and then two small posts on the side. thanks
