Corvette filter/pressure regulator issue
Ray Reynolds
Registered Member
Has anyone had a issue with these? I installed a Brand new AC Delco EP381 pump and one of the corvette reg/filter and im only getting 10lbs pressure to the rail!!! I can hear it bypassing and pushing fuel back into the tank. No its not in backwards...lol. Could it be bypassing and dumping to much back into the tank?
Is there a way you can check pressure right as it consult of the tank, it’s a good idea to rule out collapsed lines and such. It could be a bad regulator but this would be the quick way to eliminate everything else and know you have a good pump.
I'm gonna try that tonight.. I'll post my findings
I have had the same problem and it turned out that the fuel hose partially pushed itself off of the fuel sender inside the tank.
Ive ran one for over a year now, and installed a few in friend's builds. No issues with them. You may have just gotten a bad one or something else is up. Check your fuel pump mounting
Ya that's kinda what I'm thinking it might be. I'm gonna cut a window into the floor just above the sender so I can remove it without dropping the tank
