k5warwagon
I have a leak somewhere that has trasmission fluid dripping from two places on the transfer case. The vent line was not blocked. The vent on the end was not blocked. When I got under there I see fluid on the floor board above the case but also above the u-joint. Then I notice that there is literaly 3" of input shaft sticking out of the case. I measured from the u-joint to the case housing and there is 3". There was some fluid on the u-joint. Is this the source of my leak? The truck does not have a lift but the previous owner did tell me he had the rear springs re-arched.
Please help.
Thanks,
Please help.
Thanks,
