Could someone with a 208..
Mark1968
SW Ohio
Get me a measurement on the 208 shifter hole in the hump? I could probably guess but I would want this to work right.
I need to know where to cut the hole in the hump. I have the shifter pieces so I can figure out the size of the hole. I'm just not sure where it needs to be.
OK.
I will try and reference the corners from something since mine is not bolt on hump.
Give me a day and I will.
84 K10:
If you want any other measurements let me know, I'll leave it apart today...
Just remembered this,thank you. I think I can work with that.
