K5-Kelly
A couple of weekends ago I was forced to cut through the bush with my 91 K5 as the highway had a rock slide and as it was getting dark I was having a problem seeing my instrument gauges. I have great eyesight but I couldn't see a thing so the other day I took the gauge cluster out to see what was wrong and that's when I realized they were dusty and dirty! So I took them all apart and cleaned the gauges with a lightly damp (hot water) lint free paper towel and then I polished the lens with plastic polish, Novus 2 and Novus 1. I changed all the bulbs out and installed all new #168 bulbs. The cluster was equipped with the bulb and socket assembly that you are required to change out as an entire unit but I just used a tiny screw driver and broke the soldered connection loose and slipped the new bulbs in place and wrapped the bulb wires over the socket connections. Now my gauges look like new and they are really bright! As a side note when I was off road I could hear this nasty squeak noise, turns out the dash sheet metal was slightly bent and was rubbing on the instrument lens probably since it was new.
