gonefishin
ok i finally got a round pattern 205 and i was thinking about doing a 241/205 doubler but.... i am still kinda broke lol
my 241 is leaking again after i welded up the case where i cracked it last year so what would it take to put the 205 behind my nv4500?
and also my splines are wore pretty bad on my nv4500 output shaft so i was wondering if i could use my 205 with the long input to get more engagement on the splines or maybe put a 1 inch spacer if i need to? has anyone done this before?
and my belhousing bolts are all helicoiled so i don't want to remove the bellhousing can i replace the output shaft with the tranny still installed? i found one used for $50 and new for $168
