I replaced my yoke to a 1410 what should I torque it down to. Also I have to replace the orings on the axle ujoints on my shafts what do I torque the spidle to and what the easiest way to remove the caps to replace orings they are longfeilds.Thanks
Pinion nut torque is 260ft. lbs. I'm not sure about your other question. Which torque figure do you need? Are you talking about the 6 bolts that hold the spindle to the knuckle? If so those are 3/8" bolts and would torque to 45ft. lbs.
Cool thanks guys thats alot of help.
Now my question is do you guys know how to remove the caps from the axle ujoint without harming them they are new yukon shafts and longfield ujoints just that the seal on caps broke off and Bobby sent me new ones. I just need to remove the caps to replace the seals and cant figure out how to do it with out messing them up.
