lak2004
Ok few things I have run into- what sensors will I need to keep in order to make this thing run good?
TC Lockup? I have a 700r4 and I am not even sure my TC lockup was hooked up. Is it the vaccumm switch on the firewall? Mine has 2 wires running into it and it looks like a vaccumm connection on the other side. Can I run this with my TBI engine?
What is the sender with 1 wire going to it next to my oil filter? What is the thing on the back of the block that looks like some sort of sender or switch?
My tbi system is off of a 91 Van and some of the things on the newer harness are different such as washer pump connection, wiper motor connection. I think I am going to use the whole harness for the 91, should I just splice in the old connections in place of the new?
Anyone clean up harnesses on here for decent price? I want to do it myself just so I can have it done my way, but I have limited wiring schematics for the tbi setup.
Thanks!
Thanks!
I want to at least get rid of the egr and emissions stuff because I already pulled all of that. Plus I will have to get a chip burned anyway for the cam that is in the engine I will be using.
. I am guessing I will have to just splice into the new harness.
