Welding the crack is worth a try but don't count on it. Cast aluminum is very difficult to TIG. It actually has more to do with the casting quality than the welders ability. You are basically boiling the impurities out of the casting while trying to weld it up. Mold release agents, oils, sand and other nasty stuff all ends up in the casting. I did a cracked snowmobile engine case last winter and it sucked big time. Had to weld, grind it all back out, weld again, etc. If the casting is clean, not on the surface but IN the metal it will weld ok. You really can't tell until you start the weld. Its already broken so you don't have much to lose.
