elks
1997 Z71 1500 with the 5.7 and 4x4. Front diff took a rock. The housing is cracked at the lower front bolt that goes in from passenger side to drivers side. The bolt goes through a plate then ties both side of housing together. The crack is about 3/4 inch and circular around the bolt hole.
Everything else lines up good. It is on my buddies truck. For now we drained it, cleaned it, and packed with RTV to prevent it from leaking.
Does it need to be replaced? He has insurance and full coverage would replace it for $300.00. Or could we maybe weld the small crack? The RTV is temporary fix. It is a daily driver and as such he wants to fix it right.
Is the housing on the truck aluminum? I can't remember off hand we did a road side fix to seal it.
What do you think?
What do you think?
