rva3050
Registered Member
At the front seat mounding bolts. Any thoughts on fixing this?
Situation: '89 blazer. Having searched through the forum, I see that I'm not the only one to have experienced this. Unfortunately, I don't have the funds to take it to a body shop to have the pan replaced. I'd like to avoid replacing the entire pan if possible. The affected area is limited and any rust is only what you see here. I'm replacing the old seats with those from a 2001 Silverado. (will not be using the old mounding holes). My initial thought was to completely cut out the affected area and simply weld in a replacement patch. Will this work?
Thoughts or advice? I'm new so I'd appreciate any help offered.
Thanks...
Thanks...
followed by a little of that
and you get
