Crane Cam
Part Number: 113801 Grind Number: H-278-2 (REPLACES HMV-278-2)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1957 1987 CHEVROLET 8 GOOD IDLE, DAILY PERFORMANCE USAGE, MILD BRACKET RACING, 3000-3400 CRUISE RPM, 9.5 TO 10.75 COMPRESSION RATIO ADVISED. BASIC RPM 2500-5500
Engine Size Configuration
262-400 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 3114 @Valve 467 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 3294 @Valve 494
Rocker Arm Ratio 1.5
Cam Timing: TAPPET @.004
Lift: Opens Closes ADV Duration
Intake 26 BTDC 72 ABDC 278 °
Exhaust 80 BBDC 30 ATDC 290 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99848
Loads Closed 114 LBS @ 1.700 or 1 45/64
Open 324 LBS @ 1.230
Recommended RPM range with matching components
Minimum RPM 2200
Maximum RPM 6200
Valve Float 6800
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 2 BTDC 40 ABDC 109 222 °
Exhaust 56 BBDC (2) BTDC 119 234 °
Remarks:
cybrfire answered for me. In short, it fits your SBC, but not good for anything except maybe mud. Don't buy unless it is exactly what you need, or you know where to resell for $$. I bought it when I was in a car mode. :doah:
