another thing you guys need to look into is the oil pressure sending unit. it "shouldn't" allow it to start until a certain amount of oil pressure is built up.
No, thats if the fuel pump relay fails. If it took oil pressure (the switch requires around 5 psi) to start, EVERY start would take a long time, and GM didn't design the systems that way.
I'm not sure what would happen if you *disconnect* the temp switch connector. Jumping the two wires makes it go "full hot". If the ECM looks at voltage to throw a code as well, instead of ONLY using voltage to determine engine temp, then this won't work, but it won't hurt anything either. Just try it on a cold engine. Scanner would still tell you right off the bat what the sender is telling the ECM the engine temp is.
