Crate engine opinion needed
Heres the spcs on the Melling cam. it is a little bigger than the stock cam in the crate engine.
http://store.summitracing.com/partdetail.asp?part=mel-cl-mtc-1
Also the stock cam is not ground for the TBI computer and will not work well with it. The Melling cam will work fine with TBI with the stock chip. If you change the cam now before you instal the engine. You wont have to do it later if you decide to swap to TBI. Either way you will make more power/torque with the MTC1 cam than you will with the stock one
