crazy head/tail lights!!
Neil
Dothan,Alabama
My '78 K5 has some serious light problems.. 1. apply brake when not running and headlights come on, no rear brake lights come on..2. when turn signal is levered in postiion, emergency flashers come on. 3. no brake lights, just rear running lights and headlights when light switch is pulled out, along with running lights, are the rear white reverse lights. Somehow my brake and headlights are reversed I know. Where do I start!!!! It is like someone has played an evil trick on my K5's lights !!
Neil H. Alabama.. "It's a full size thang, Jeep owners don't understand!!" '78 K5 400ci 4x4 AT,AC,PW Cheyenne., '74 C10 4x2
Start with a new Painless wiring harness. That should take care of your troubles.
My 73 K5 <a target="_blank" href=http://www.geocities.com/xk5blazerx/73k5.htm>http://www.geocities.com/xk5blazerx/73k5.htm</a> 350/TH350/NP203, Q-jet, Edelbrock intake, Vortec heads, 4" lift, and 36" TSL's
I think you need an Exorcist.
'89 K5 Silverado..."You can’t have a real adventure, unless the outcome is truly uncertain".
