Crew Cab rear seating
konajoe
Massachusetts, U.S.A.
I'm looking to pick up a 1985 C20 "Bonus Cab" basically it looks like a regular one ton crew cab, tall frame, hydroboost and 14bolt ff etc but it has no rear seat. Does anyone know if the crew cabs use two front bench seats or a Suburban seat for the back seat.
Thanks
Just to clarify, do not use a front bench from a crew cab, only use a reg cab seat as stated. A crew cab front bench seat back does not tilt forward.
My crewcab has the front bench seat with the forward tilt. Obviously the P/O swapped it out but I think it's cool, I can reach in the back without having to open the rear doors. :D
You'll need to either swap out or modify the mounting brackets. Look at the floor under the seats and you'll understand. I got front & rear bucket seats out of a 91 suburban conversion to put in my truck when I get them re-upholstered and new brackets made for rear seats.
I have a pair of K5 buckets and center console that i could install up front and use the front bench for the back seat, it just wouldn't flip forward.
