Wanted Crewcab interior roof braces
muddybuddy
1 ton status
Northern, VA
Looking for a couple interior roof braces. This would be from someone scrapping a crewcab cab most likely. I believe each crew can has 1 or 2 (they go from left to right like a cross member that supports the roof). Let me know what you got.
Also the front brace from a suburban would work as well (before the roof pops up) @kennyw if you are able to cut it out of the sub you are parting$
That looks like it is the same as the Suburban. I have no problem pulling the parts and will sell them cheap, but shipping large parts across country gets expensive.
Yea seems the front one should be the same, you can see roof rises afterwards in your picture. At least i’m hoping they are the same.
The suburban roof is higher than the crewcab/regular cab roof, see attached photos, of pickup back panel. You can see suburban roof is couple inches higher. I’m wanting to use crew cab roof skin, so cant use the back cross braces
I always thought they had the same profile because of the ribs looking the same but never compared them side by side before. So, that first crossmember does look to be the same between suburban and crewcab from photos I can find. Give me a couple weeks and I will be ready to cut up this Suburban.
The crew cabs aren't a double panel roof like a regular cab? I've never had the headliner out of either of mine.
