So I have had a hand full of the k5's and a couple GMC jimmy versions. To set the record straight..... The two bolts on each side of the cross member that have the tall bushing/shims.... How are they to be installed? I have seen it were the tall bushing goes between the cross member and the frame and I have seen the cross member bolt right up tight against the frame and the tall shim basically was used to take up space on the bolt before installing the nut.
Please advise...
Please advise...
