.........From where I can see, it looks like you have the '84 and older 205 setup. This will bolt and sit right on your current '74 crossmember. You will only need to redrill 4 holes in the frame to mate the 'member to it. Its that simple.
Now if you have the '85 - '91 case, you would need to swap the 'member for the newer year and also redrill holes in the frame.
Doesn't matter, you're gonna redrill holes either way. I wouldn't change anything as far as using the stock type crossmember.
