broncoman6524
I have read the tech article and have a basic knowledge of what is done...
Ok so for my trazer i would like to run crossover because of the lift, i think its less stress on parts. Now i have to have my passenger side knuckle drilled and tapped. then i have to buy a steering arm. correct? and bolt it on.
then i need to swap in a 4x2 sector shaft into the existing box, or get a 4x2 box adn swap it in. i dont have a motor or lines yet so im not hard over on the years.
after that is done do i HAVE to have the jeep pitman arm? is there a reason i can't use a dropped pitman arm to lower my draglink which i would need to make, and therefore i wouldnt need to cut up my crossmember...or am i not in the right thoughts here?
then for the draglink i need to center every thing measure twice cut once kinda deal.
am i forgeting anything? or are some of my thoughts incorrect? im trying to explain this to my dad and show him the benefits so the more knowledgealbe i am the better i can edumacate him
