So I had my tie rod above the leaf springs but it was to close to the pitman arm. I flipped it below the steering arms now, but not sure all is good. At full lock to the passenger side (The picture below is full lock) there is only about a 1/4 of space between the bottom of the leaf spring and the tie rod, it dose not hit the leaf but not sure what will happen when I flex it out and tuck the tire. I had to add 1/2 spacer, used the misalignment washers and installed a easy inch to get it to clear the leafs.
Also, check out my ram assist mounting location and give me hour thoughts. The bracket on the axle and the tabs on the tie rod sit lower then the leaf springs so thinking it may be good to go.
