rampage
3/4 ton status
I’m replacing my buddy’s floor mat in his ‘84 truck. Had to remove the front two seat mounting bolts to get the mat under the seat and found out the the genius who replaced the carpet cross threaded the bolts that hold the seat to the floor.
I’m guessing he used a power tool and didn’t start them by hand. Looks like my options to repair it are limited since the captive nuts are both inaccessible because it has gas tanks on either side. So it looks like I have two ways to go. First is to try to run a tap through them to clean them up. Which type of tap is best to do this - taper, plug or bottoming tap? Second is to use a Heli-coil.
Any tips or other options or is that about it? Dropping the tanks and re-welding the cage is above my pay scale.
I’m guessing he used a power tool and didn’t start them by hand. Looks like my options to repair it are limited since the captive nuts are both inaccessible because it has gas tanks on either side. So it looks like I have two ways to go. First is to try to run a tap through them to clean them up. Which type of tap is best to do this - taper, plug or bottoming tap? Second is to use a Heli-coil.Any tips or other options or is that about it? Dropping the tanks and re-welding the cage is above my pay scale.
