Alright, so I have reached a pivotal point in my build. I feel as though the information I have and what I would like answered would benefit others, since I have spent numerous hours trying to decipher through and find out which crossmember works for the nv4500 swap. I personally have a '77 k10 short bed frame going together. I have began my nv4500 conversion, OEM hydraulic bellhousing, and np208 transfer case. The frame originally had a th350 crossmember, and I have seen others fabricate some sort of spacer/mount to make the "flat" th350 crossmember work. However I do not have any of the proper equipment nor know-how to make that happen, so I am trying to figure out what will work to use the nv4500's rubber block mount with a factory transmission crossmember from another truck. Here's my understanding:
-The 700r4 has the same footprint as an Nv4500, therefore, a 700r4 crossmember should work. However, through my research, there appears to be two styles, "Double Hump" or "W" and another style of a double hump crossmember, making an S shape. I read on a 4wheeler magazine article of a guy who swapped a nv4500 crossmember into his m1008, and he used an s style crossmember, which is from a 85-87 700r4 truck.
-The Sm465 crossmember ALSO has the same footprint as the nv4500, and I believe the same mount, so doesn't this mean that this crossmember can be used?
If anyone has any experience behind this swap or if they can confirm the information I have, it would be greatly appreciated.
