The length of the draglink is what improves bump steer not the angle or bend. The only time I know the angle matters is when you have a panhard bar on the front axle like a 73-79 ford coil spring radius arm set-up. In that style application the draglink must be parralel w/ the panhard bar.
Flexy long travel suspensions usually have more steer than the stock stuff and soft springs compound this problem. Hope you see the reason I asked what you were calling bumpsteer, it got everybody on the same page
