Crossover knuckle for D44
broncoman6524
chuluota Fl
Anybody got one? Or better yet everything I would need save for the actual box to conver to cross-over?
Thanks!
I have 2 sets of flattops. There are completely stock, pulled off the truck and that's it. Will need to be milled/drilled/tapped.
wanted in the sale section again :doah:
and i have a guys info saved at home for 50 bucks he mills and drills taps and return ships it to you for a knuckle. will post up tonight.
o.k. guys here ya go. the info for YOU send YOUR knuckle to him and HE does the work.
i sent one out for a friend. and it was fast and good. will send more if i ever need to. a+++++ in my book.
http://www.jnutter.com/index.html
special is #1 knuckle drill/mill/tap/return ship 50 bucks.
You'll need both, 10b and D44 have the tie rod on different sided (top side, bottom side)
