crossover question
eightyone
long island
does the steering box on a 94 4 wheel drive turn the correct way for crosover steering? and does anyone know anything about ford dana 60's? what steering arm do i run? the sas kit sais i need crossover, but dont the fords steer on the pasenger side anyway? any sas info is apreciated. thanks.
not sur about the arm but you dont need a new box. you can get a drop pitman arm and install it on your box the way it is.
Yes the IFS trucks steering boxes are up inside the frame. And they steer left to right instead of front to back.
The Ford 60 steer just like the Chevy's on the driver side. But when you put them on a IFS truck you can't hook up the steering unless you go to Crossover.
Did I confuse you?
