lochenjons
I thought with the steering wheel in the center between lock to lock the pitman arm faces directly back, parallel to the frame with crossover. I just got a pitman arm from an '82 furd van that was supposed to work. But with the way the splines are on the 2wd steering shaft, it faces either inside the frame or outside. Is this right/is this still going to work/does it matter/ is this still going to work/which way sohuld it face/is this still going to work?
thanks!
thanks!
. Its not like that. its like this:
