crossover steering arm
rob h
frackville,pa
I have a bolt on crossover steering arm for a dana 60, built in king pin cap with grease fitting, one inch thick , front hole tapered for draglink end. Looking to get 50.00 plus shipping, ship prob under ten bucks....
Pic with studs, studs not included, was blasted and painted black, was a shaker built older piece. Front hole is tapered the rear hole is still straight thru, can be tapered or can use a heim..
is this set up for a 1 ton TRE or a heim?
The whole arm (was) set up for heims, it (now) has the front hole tapered for a draglink rod end.(my crossover uses the factory draglink ends)(longer style) The rear hole is still straight thru can be tapered also...Also shouldbe able to include studs and nuts that are shown as long as they come out easily.
