Crossover steering, do I need a drop pitman arm?
hidesertwheelin
Hesperia, CA
I'm going with crossover steering on my Dana 60. It will have a 4" springg lift and 1" zero rates. I also already have a bent drag link. Do I need a drop pitman arm also?
Yes you need the drop pitman. I got mine from ORD, pretty sure it was a 3.5 inch drop.
You have the 2wd steering box right?
Can't wait to see yours in person at Rubicon, Wetsomethingsomething
I don't want to argue with different terms being used. So, here is how I see them.
1) I bought a drop pitman from ORD, was too much, didn't like it. Then come to find out they offer a shallower drop than what originally came with the kit. It should have been used on my 4" lift. The deeper drop was more for 6"+.
2) The one I went with is from a Ford van, much the same as the shallow drop from ORD.
So, order the least amount of "drop" as you can, since you are running a low lift and you already have a bent draglink. I ended up, after changing axles etc, with a very shallow pitman arm and straight draglink. :D With the D44 I started with, a bent draglink wasn't going to work. With the D60, it would be fine.
One pilot said we-too-low the other pilot said now we crash, ding-bang-ow
Yeah the one i got from ORD is in fact the 3.5 inch drop. The way it looks i dont think i could get away with the 1.5 inch drop, it would hit the frame.
My front lift springs are pretty flat so i dont have any rubbing so far.
Keep in mind if you have a 6.5" center to center crossover arm then you really should use a 6.5" pitman arm to keep the steering ratio the same.
Mine hit the weld from the frame reinforcement piece. So I ground the weld down and it fit even with the lower frame brace welded in. I think this arm with the bent draglink would be awesome. Not sure if I care enough to switch though :D
i just swapped from the 3.5" drop arm to the shallower one. you want my old one?
That's a very god point!
And really something to think about, when getting the arms from different sources.
My experience says you can get away with a 10% shorter pitman arm and still get lock to lock steering while flexing.
But it's cutting it close...
Yeah it does make a difference. The 1.5 inch drop is actually 6.25 so yeah its probably plus or minus a 1/4 inch.
