need steering arm
brakelines
shocks
driveshaft spacers or lengthen
unless ur have this stuff already...
brakelines
shocks
Bad bushings will definitely lead to problems.... and factory rubber bushings are 40 years old and will be dry-rotted.
Are you staying with a 35" tire? Any plans to go to a D60 front? The only reason I ask is because the D60 will give you some free "lift" vs a D44 due to the springpad height. If the truck sat level with a D44, it will sit higher if a D60 is swapped in.
The rear springs are the hardest to guess. Blazers typically need more lift spring in the back than the front to compensate for the extra weight that the Blazer has vs. a pickup truck. It seems that a 2" rear spring along with a 4" shackle flip will get you close, and if you still need more to level things out, you can add a 1" zero rate and/or a longer rear shackle to give you up to 2 additional inches of lift...
Unfortunately, there really isn't such a thing as a "soft" 6" front leaf spring... it's just too much arch across a short span to really keep the spring rate low.
just add some shocks to absorb the sway.
sorry, couldn't help it... i was trying to find the pic where the guy used rebar to make cross steer.
Trying to cure the wander with my Jimmy too. I ordered ORD's shackle kit but I know I need balljoints too. Does anyone have a good online source?
