crossover steering Q's?
nicotine
alright i need to know a few things about crossover steering i know everything i need what i need to know is if i have a 4 inch lift now and i put crossover on now and later i go a couple incges bigger both in lift and tires will i have to change anything steering wise? also what i the average price any of you guys have setup croosover for a dana 44 ?
I spent about $575. for mine, with the hydro assist.... adding a few inches lift should be no problem...
FLAT TOPS 120-
Steering arm (sky) 75-
draglink (sky) 65-
TREs (moog) 70-
Tie Rod * (ebay) 70-
1104 pitman arm 65-
REMER 1.5/ft 30-
Ram 8" x 1.5" 50-
hose and fittings 30-
* I bought a new early style tie rod because the stock one hit the springs with the flat top knuckles, you could use a zero rate to avoid this.
I don't think change in a couple inches of lift will effect anything. Price varies around what parts you can get used or cheaper. I got a good deal on Knuckles and a 2wd box, but I still spent around $500 with Sky Draglink, HD Tie-Rod, and a Tall Arm.
