Crossover ... what , err, pitman arm?
Have you noticed that the stock 2wd pitman arm has the joint built into it and not the other way around? No you can't. Not even close. Won't work.
Triaged said:
This pitman arm has just enough drop to clear the frame and works great with my 4" of lift up front.
Do you have any contact with the front cross member under full stuff?
No. But note from earlier in this thread that I have a 1st gen. My drag link is very flat and has no bend in it.
