Can you do it? Or will it hit the crossmember/oil pan/etc?
Martin
Martin
how much up travel does stock suspension have anyways? LOL! maybe some bump stops tooI think the biggest limiting factor is leaf spring to pitman arm clearance.
So zero-rates don't make any difference.
And don't use the popular superlift 1104 pitman arm if you have a low lift,
since that one has a pretty big drop, decreasing the clearance even further.
I have a set of three leaf front springs, and a zero rate on the front of my Suburban. It also has the stock crossmember. I need to replace a bunch of stuff in the steering, so I figured why not just do crossover? I already have a external hub Dana 44 from a '75 K20 in the front, and ORD has their crossover kits on sale currently.
Martin
Dragging up an old thread..
Is the main intereference the engine crossmember, and springs?
I am moving the engine and crossmember back 5-6 inches to fit a Willys body, and have a couple ideas on lift.
If the 37 tire will clear with stock uptravel, it won't get a lift, but will get some 52 springs on the front for flex... LCOG
If I do add a lift it won't be anymore than 4 in.
So can I do a crossover at stock height, with the engine crossmember not being a factor?
thanks.. still studying and reading!!![]()
52" springs in the front will give you 3-5" of lift weather you want it or not
So, I think it would work just fine.
With the crossmember moved back, you could probably use a straight drag link btw.
And you could probably use the high clearance pitman arm that Chris spoke of earlier.
True you're going to cut some of the lift out but I'd be surprised if it was still dead level no lift.
