I’m getting ready to swap my front axle out for another 10 bolt to get better gears and was wondering if it’d be worth the trouble to go ahead and do cross over steering while I’m at it? The truck is stock height with 32’s on it right now but I plan on doing a small lift in a year or two which is when I was originally planning on doing something with the steering but since I’ll already be putting the drilled and tapped flat top knuckles on this axle when I replace the ball joints I’m wondering if I should do it now. I don’t think I’ve ever seen anyone do it on a non-lifted truck so I’m not sure if it’s even possible or if it’d be worth the hassle but since I already have half the stuff and will have everything torn apart anyways I thought it’d be worth asking… What do you guys think?
ps I’d love to throw a Dana 60 in there but they cost a freakin fortune where I’m at if you can find one so it’s not in the budget right now. Plus I don’t wheel it very often and since I only plan on running 33’s or maybe 35’s after the lift, the 10 bolt should be fine for the time being.
