89' Blazer.
My resto work is moving along quite well so far. I'm trying to get the cruise control to work and it actually engaged slightly a few times. Problem is, it's certainly not consistent or reliable. So I'm looking for some input.
Things I've done:
- New turn signal blinker assembly with built in cruise switches
- Adjusted the brake pedal switch to be right against the stop and also the vacuum line switch at the brake pedal
- New EGR valve with new vacuum hoses
Sometimes it holds the speed (barely) and other times....nothing. When I do get it, I try to adjust to accelerate via the switch on the lever but it doesn't really do much.
Thinking the whole system was bad, I got another suction controller and electronic box from a salvage guy for $5. Have no idea if they work or not.
If it can engage in anyway, is the system salvageable? Are the 37" tires really making it hard to actually set a speed and would it interfere with the VSS module behind the instrument cluster?
Any tips would be great! Thanks!
Things I've done:
