I decided to ditch the crush sleeve and picked up the crush sleeve eliminator kit from Yukon gear. I was browsing over the Billavista 14 bolt gear set up article in which the crush sleeve is used and so then I started to process the differences in my mind with setting up the pinion bearing preload using the eliminator kit.
Although I know there is usually more than one method to do things, I read where he recommended to have the seal in place in the pinion bearing housing when preload is being checked. Basically, the whole pinion assembly is assembled when doing it like that. So then I realized the crush sleeve may have its benefits over the eliminator as far as the installation goes (assuming it doesn't get crushed too much, requiring the proses to start over from scratch with a new crush sleeve).
Reason I thought that is because every time a shim from the kit needs to be added or removed to get to the correct pinion bearing preload spec (25-35 ft. Lb with new bearings), you'll have to remove the seal and outer pinion bearing which creates the possibility of messing up the new seal and/or outer bearing. So I was thinking that in order to save headaches, 1- I wouldn't install the oil seal until after I got preload set (hopefully that won't cause over preload from the resistance of the seal not being present) and 2- I guess I'll get the old outer pinion bearing and ream it out so it can slide on and off the pinion shaft while I'm adding/removing shims then press the new bearing on after I get the shim count where it has to be. Any experience or advise that anyone can offer? I just don't want to be taking a new seal and outer bearing on and off. I'm not sure how to get a close starting point with the preload shims besides measuring the old crush sleeve even though I have all new bearings and pinion.
