MEMO43
Ok as the title says
I have a cs144 alternator installed in my rig.
it's an 85 chevy k20 with a l31 (roller cam from a 98 1500). Summit Racing max efi, dual windsor fans, relay mods to both low/high headlights. I have allstock gauges with no dummy lights, just the basic full sweep style.
I 'm running the serpentine system with reverse flow water pump and currently have a cs144 (140 amp) alternator. Brand new, along with an 850 CCA AGM battery.
I have the adapter plug with the resistor in-place.
My dilemma is that at the gauge I'm only showing 13.5 . At the battery I'm showing 14.6 same as the alternator batt stud as well as the junction block. I've verified good grounds and solid connections etc etc. I'm using 4 gauge battery wires for both pos and negative, to include battery to frame. for the engine to frame I'm using braided ground straps total of 2. everything else is 10 gauge.
My headlights dim at night when the electric fans kick on, and voltage readings drop.
Do I really need the resistor at the adapter plug since I don't have dummy lights. I'm thinking that is what is keeping my from getting full voltage output from the alternator, I have another adapter plug without the resistor ready to swap out but wanted to make sure I'm not going to fry anything.
Thanks in advance
Thanks in advance
