cucv 6.2 alternator bracket
blazin_blazer
central arkansas
the cast alt bracket off of the left side of a cucv w/2 alternators, will that bracket fit on a bbc? i want to run dual alts w/2 separate/isolated 12v systems. 1 for ignition/hei & starter, 1 for the rest of the truck w/relays allowing the 2nd battery to run the whole truck & isolate the 1st bat should the starting battery drain dead, so it won't try to equalize power between the hot & dead battery.
ok, thanks,..i've never had a diesel, so i wasn't sure if the accessory holes in the head was different or not. i guess i'll try and figure something out.
anyone out there running 2 alternators on a bbc?
