If my CUCV sits more than a day it loses fuel prime. It starts instantly, runs for a few seconds then dies and is a bear to get re-started.
Recently I started immediately cranking for 2-3 revolutions before the glow plugs cycle (so it won't start), stopping and then cracking the drain on the top of the CUCV-type square fuel filter. The pressure from the quick crank pushes a bunch of airy fuel. After that I close the valve and start the truck and it no longer dies.
So, it's losing prime in or around the fuel filter area. I don't see any sign that it is leaking anywhere. The fuel filter is less than a year old so I'm hoping it's not leaking around the rubber grommets where the lines go into the filter but I suppose it is possible, or the is a pinhole in the feed line from the tank. It's under suction, not pressure so that might explain why I don't see anything wet. It would also explain getting air in but not fuel out.
What would you do? Pull, lube seals and reinstall fuel filter? Replace filter even though it doesn't have 3000 miles and one year on it? Replace fuel line from tank? If so is it just regular fuel line or something specific? What is the most common failure point?
